TwinTurbo.NET: Nissan 300ZX forum - Like I said its 90 amp as opposed to 80 for the n/a
Subject Like I said its 90 amp as opposed to 80 for the n/a
Posted by ZiNnYc on June 23, 2008 at 4:42 PM
  This message has been viewed 136 times.
In Reply To are they different? pep boys told me they only have one for posted by Felix (NJ) on June 23, 2008 at 11:43 AM
Message its better to have a higher producing alternator for your setup. Hopefully your system is installed properly with a decent ANL fuse for your amp power, perhaps a decent cap if youre constantly bumping the system, and a good battery (Optima Yellow works for my 880Watter). New terminals, new ground to firewall (and tranny if you have some time), grounding net to have a bulletproof powered system.
make sure your PS system is tight with no leaks. check it before and after alternator install, you can even cause a problem when installing it, hoses are right there and its easy to bang on. leaky PS system = alternator killer
